Rejected a request to open a socket due to incorrect socket type.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Invalid socket type %p2% on open socket request. Must be raw or datagram. Application socket handle = %p1% Socket family = %p3% Socket protocol = %p4%
| Name | Type |
| p1 | uInt32 |
| p2 | xInt32 |
| p3 | xInt32 |
| p4 | xInt32 |
